Tomorrow morning I'm hopefully completing installation of a Mallory Unilite distributor in my wife's 3000 MK I--I'm using the model with vacuum advance. The literature says that the unit as set from the factory has 24 degrees of advance--the springs can be changed to get up to 28 degrees I believe so I guess they are referring to centifugal?
The engine (cam, carbs, etc.) is stock as far as I know. What should the initial/ idle advance be and what should the total be and at revs. Should the timing be set with vacuum tube attached or capped off?
