ronzet
As I may have mentioned, now that hte grounding issue is resolved... What should I set the inital carb setting on the jet setting (the big screw on the inside right side of the carbs.. I took it all the way down and then backed off 1 1/4 turns... I rebuilt both carbs with new needle valves, etc
??? /ubbthreads/images/graemlins/confused.gif
Thanks...
Thanks...
Hi Guest!
