KVH
I'm revising an earlier post because I didn't give enough (or correct) facts:
I'm not seeing any significant difference with my infrared thermometer, top to bottom, but that could be due to the opening temperature of the thermostat which I believe is 180--and I keep shutting down the engine once my gadget reads 192 or higher.
When I'm near the redline on the gauge, I get 162 on top and 158 to 161 on bottom. Not very helpful.
When I allow the car to idle longer, however, the upper temp goes to about 193 (before I turn off the engine fearing damage), but the bottom was in the range of 178, and I don't imagine that shows any significant cooling--or is very helpful in the analysis.
I don't imagine the radiator can cool the water at idle anywhere in the summer in Arizona, anyway.
Every time I've removed a thermostat to check it, it's been fine, so I'm reluctant to jump to conclusions here. Except for the idling test, I took the readings after a good drive where the temp gauge was at 3/4, near, but not on, the red mark.
Maybe the question I should ask is what the best test should be for my thermostat operation? What temperature disparities at idle should I see when it's near redline? I don't think what I was doing is telling me anything.
Thanks for any ideas.
Hi Guest!
