T-Series Inertia fuel cutoff switch
Kimberly
If you wish to install an electric inertia switch, use the white wire from the ignition switch to the fuel pump. Later cars locate the under the dash on the firewall. If you have any doubts as to the wiring, look at the wiring diagram for a late model B. If you don't have a wiring diagram, they are available at https://www.advanceautowire.com click on stock schematics.
If you wish to install one on the fuel line, just locate it under the bonnet.
tony barnhill
Great Pumpkin - R.I.P
Most of the OE ones have been removed or bypassed because by now they all leak - & replacements aren't available.
R6MGS
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif OE inertia switch /ubbthreads/images/graemlins/pukeface.gif
Kimberly
I don't have the one installed in the fuel line, but I still have the electric cut-off one under the dash. Are there any disadvantages to keeping the electric one? And what about an inertia cut-off valve from another make of vehicle? I have worked on a lot of makes and MG is the only one where I have seen fuel leaks from the inertia valve. I worked at a DOT and EPA conversion shop for gray market vehicles usually imported from Europe and installing roll-over valves in the fuel lines was just one item on the list of things to do so the cars could be registered in the U.S.
Z
zblu
Hi Kimberly,
Yes its the electric one I am looking for, cuts power to the fuel pump in the event of a hard enough knock!, also as an extra deterrent!
Think they work like a pendulum in a container or like a mercury switch, the type I am interested are push button resettable, not activated by oil pressure drop off tho.
Other makes considered!
Kimberly
If you have a source for used late model MG B parts, you may be able to get one there. Moss motors sells them new, but they are a bit pricey.
tony barnhill
Electrical: I have those used - & can get those new also....but, were it me, I'd buy the new one. Contact me off-bbs.
steveg Fuel pump inertia cutoff switch Austin Healey 33
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
GTP1960 TR2/3/3A Fuel pump inertia switch vs. dead engine switch? Triumph 14
B T-Series Fuel pump inertia switch? MG 4
Z Fuel inertia switch Austin Healey 3
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
Gliderman8 TR6 Inertia switch location Triumph 9
Gliderman8 TR6 Inertia switch mounting location Triumph 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
H TR2/3/3A SECURON INERTIA SEATBELT ON TR3A Triumph 5
glemon T-Series MGB Inertia Switch MG 13
B Inertia, Ennui Triumph 30
J TR6 Inertia cut out [off] switch TR6 Triumph 9
Daimlerdb18 How to overcome restoration inertia MG 30
M TR6 TR6 inertia seat belts Triumph 8
A Inertia Switch Spridgets 1
B inertia reel seat belts Austin Healey 1
AndreL TR6 Conversion to electric fuel pump Triumph 6
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
