TR4/4A Inconspicuous or period-correct backup light for TR4
Gerald_Gordon
I would like to add a backup light to my TR4 that would be inconspicuous when dark yet effective when lit, such as a string of super-bright white LEDs mounted below the bottom edge of the panel below the rear bumper or else Frenched into it. Alternatively, would there be a period-correct light that would not have to be hidden? Suggestions would be welcome.
Gerald_Gordon
Gerald_Gordon
Randall and Wayne, both lamps look good. Thank you for your suggestions.
Mink
I have a friend with a TR250 - his factory reverse lights are the same assembly as the front turn signals with a clear lense.
JerryVV
Here is a photo of my backup light installed on my 4A. It's the 494 example shown above. I made a small bracket that attaches to a bumper bolt. My 4A @ PVGP 2011.jpg
trrdster2000
Looks nice Jerry, I did one on each side for a friend, very effective.
Wayne
Gerald_Gordon
Gerald_Gordon
Jerry, thank you for the photograph of your installation, which I will probably copy.
JerryVV
Gerald, (I'm another Gerald) if I recall I actually drilled a hole in the bumper bracket to mount the light. The car is in storage now but I can take a photo once I revive it for spring driving. I also drilled and tapped the transmission top cover for an isolation switch so the light turns on when I shift into reverse. That takes a bit of work but if you now have access to the transmission top cover I'd recommend doing the same. Lets take this to regular e-mail. My e-mail is jerryvv @ roadrunner dot com
JVV
Hamish Racing General TR 1964 period racing uk Triumph 1
Hamish Racing Period racing 1963 video Jaguar 0
Hamish Racing Period racing 1963 video British Motor Corp 0
Hamish Racing Post-War Other Period 1963 racing film Triumph 15
HealeyRick Period 100 Review Austin Healey 6
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
M Period Spridget articles Spridgets 5
M General TR Period Triumph articles Triumph 5
M Period Healey articles Austin Healey 4
HealeyRick Summer in the Country/ Period Mods Austin Healey 15
simon1966 Period Upgrades? Austin Healey 12
Schroeders Period Cloth Wiring Harness Loom Material Needed Austin Healey 5
L Engine break-in period Spridgets 6
H Period correct license plates Austin Healey 18
I British period license plates Spridgets 8
newmexTR3 Period switches / light relay Triumph 6
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
Mickey Richaud Wedge Period Ad/Music for the Wedge Triumph 2
M period correct jack Triumph 16
Team_Sprite Period bugeye reviews/test reports partially up Spridgets 1
angelfj1 Period Correct Switch for Driving Lights Austin Healey 2
angelfj1 T-Series Period Correct Switch for Driving Lights MG 6
angelfj1 Period Correct Switch for Driving Lights Other British Cars 3
angelfj1 Period Switch for Driving and Fog Lamps Triumph 3
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
