AndrewMawson
[ QUOTE ]
Spinning the water pump faster will generally cause even more overheating, as the flow of the coolant through the radiator is too fast for proper heat transfer.
Jeff
[/ QUOTE ]
You know this has had me thinking for a while - and I'm convinced it cannot be true.
The rate of energy loss from the radiator is approximately proportional to the absolute temperature difference between the air and the radiator. If the water is pumped faster and the radiator thus heats up as more energy is going into it, more heat will be lost from the system not less. To maximise the loss from the radiator you want to get its temperature as close to engine temperature as possible - taking it to extremes, pumping infinately fast means that the water will be at the same temperature in all parts of the system ie engine temperature /ubbthreads/images/graemlins/confused.gif
Jeff
[/ QUOTE ]
