For the horns, check to make sure connections are present and tight, and check to see if there's still a ground strap across the steering column coupling down near the rack. If they're original horns, and you're getting current to them, hopefully they're of the adjustable type and a slight turn of that adjustment screw will bring them back.jdubois said:Only mechanical issues are a non-functioning horn and a starter which doesn't disengage cleanly. The horn isn't a big deal, I'm sure. I'm figuring the starter just needs to be taken apart and cleaned up, because it doesn't have any trouble starting the car, just sounds like heck for a second or two after the engine fires up. Anyway, I wanna get that sorted out soon, on the chance it's chewing up the ring gear.
As for the starter, could just be that you need to pull it out and wash down the starter drive...then put it back in. Some people like to put a bit of dry graphite lubricant on it, but basically it just all needs to be clean of grease and other foreign matter.
/bcforum/images/%%GRAEMLIN_URL%%/cool.gifjdubois said:Andrew, thanks for the heads up on the rocker cover color. I asked the seller about it and he had painted it that orange color himself and confirmed it was more of a copper color before he did that.
So long as it doesn't spend all its time there...and I suspect it won't! /bcforum/images/%%GRAEMLIN_URL%%/driving.gifjdubois said:Feels good to have a Spit in the garage again!
Hi Guest!
