I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas]
chrisyoung
I haven' seen the car yet. The seller says:
It runs, drives, and stops. Just needs to be sorted out. Things like the right turn signal doesn't work and a whine in 1st gear. Odometer shows 71,867.
Any thoughts or advice?
Jim_Gruber
All Spridgets up to 74 whine in first gear as 1st gear is straight cut not synchro. To shift into first be completely stopped, shift into second and then go to first.
IT will also whine equally in reverse ad 1st and R share the same gear.
Jim_Gruber
Turn Signal like oxidation on wire connection, clean off the green and all will likely work or it's a bad bulb or bad ground. Clean the green off of all wire connections and all will be well. And new Turn Signal Switches are available from MOSS and other suppliers but likely bad ground.
Jim_Gruber
Last of the A Series Engines. '67 was peak horsepower years. Each year engines lost more and more HP. 75 started with the Rubber Bumper Spridgets - Yuck IMHO. Like the Round Wheel Arches a plus, after 75 the bumpers added 200 lbs of additional weight and suspension needed t obe raised by 2+ inches for conform to US Safety standards for minimum height. Front end is the weak link. IF there is any play in front end, replacing front suspension with shocks, A Arms, Major Suspension Kit. brakes, wheel bearings while you are in there, budget $1,000. Check for oil leaks under the car, all 1275's leak out the rear seal, but some are far worse than others. Rust is the key, A Posts, Rockers, Rear Quarter panels, Rear Suspension Mounting Points. Area behind back seats where floor meets rear bulkhead. Rear Bulkhead is a bitch to replace. All sheet metal is available just depends on how handy you are.
You will end up going through the entire car cleaning every wiring connection to get the green off of the copper. But car is relatively simple.
Google Awakening a Sleeping Sprite. Gives you tips on things hat will need fixed to properly get a Spridget back on the road after a long nap. But will also give you tips to look at.
Jim_Gruber
Finally,a well sorted Spridget is an incredibly fun car to own. An will give you the opportunity to practice problem solving. Lots of years deferred maintenance on these cars. When right, on a curvy B Road... Second most fun thing I can think of.
Jim_Gruber
Sitting in my Driveway as I type tis, out of the garage, top down, 77 degrees, and ready to go for a romp on some twisties in about 1 hour when my S.O. arrives. He got out for about a 20 minutes run with temps in low 50's a while back but first time for a fun romp since the Fall. View attachment 53188
Jim_Gruber
What Still has not happened is getting the 1275 and 5 Speed installed. The trusty 948 with Cooper S Head, Cam, LCB, and HS-2's will need to do for today.
sim looking for 2 valve spring kippers for a 948 Spridgets 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 2
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
C Looking for SoCal restoration shop Austin Healey 4
