tinman58
I'm just gonna change the brake and clutch lines from the can to the brake and clutch cylinders.
Well there was a small leak and the paint was bubbled a little, so I removed the brake and clutch cylinders and the peddle assembly to get at the piece that the whole assembly bolts to. Removed it all and striped the paint off. If I remember right that piece that the assembly bolts to is supposed to be black. If that is right what paint should I use that will stand up to brake fluid? I don't want to wait to have powder coated.
