Steve_Lawrence
I cooked my Pertronix unit a while back and put points back in. I checked that there was power to the coil and also that the points were opening and closing, but I still couldn't get any spark. I replaced the worn strap that grounds the guts of the distributor, as it was down to just a few strands of wire. No spark. I tried a jumper cable to ground the engine in case it was a bad ground strap. No spark. I put in another distrtibutor. All was well.
After setting the timing by ear, I headed out to gas her up and to check for pinging under load. When I slowed to make a turn about a half mile from home she died. Now I'm back to the same place. power to the coil, points doing their thing. No spark.
What am I not thinking of here? I'm hoping that the group's collective wisdom can point me to some simple problem that can be easily fixed, leaving me feeling stupid, but with a running Midget./bcforum/images/%%GRAEMLIN_URL%%/wall.gif
The Midget is a '74, if that makes any difference.
Hi Guest!
