I'm a dummy
DNK
Put the top up on the Wedge to take to an alignment shop today. Installed the fresh air intake in the engine compartment and went to check the battery in the trunk to see if it was connected and
"what the ..."
The gas cap was gone.
Got gas last week down the street and drove it straight home.Dang. Drove back to see if any one turned it in. No luck. Wife ,dog and I retraced the route too see if I could find it. Nope. Of course 90% of the leaves have fallen in that time so I could have walked right by it.
Thanks to the generosity of the List I will have a new one soon.
Never did get to the alignment shop!
Brosky
Better than leaving the only rotor you have on a bench and then cleaning the bench the day before trash pickup. You know the rest of this story doesn't get any better.........
Platinum
I "fixed" that possibility, Don... a piece of brass pull-chain (think terlet tank) attaching the cap to an inner hinge screw of the access lid.
KVH
I think I know what's really bothering you. The fact that it's still out there, under some leaves, sitting cocked between a few rocks, in a spot not entirely expected, blending with the landscape.
I once walked three miles of road looking for my jet centering tool. Didn't find it. But I did find my gas cap once, and it was thirty feet off the road, farther than I would have guessed.
BobbyD
Gas Cap? That's nothing! Back in '07 I was at VTR in Valley Forge PA. I topped off with oil before leaving on the 4 hours drive home. Driving 2 hours toward home on Saturday, taking a short break at a rest area and popping the hood to find oil EVERYWHERE! But there was the oil cap sitting on the battery where I had left it. As bad as it looked, it was mostly splatter and not enough was gone to even add oil to the engine. The "mostly splatter" took all day to clean up. The good news is that it happened on the way home and not on the way to the convention! :driving:
DNK
DNK
SCguy said:
We've all done it! Now I always leave the cap on the car when filling up.
Larry, that's where i put it.
I always have a paper towel under the nozzle when I pull it out so it won't drip on the car. Went to throw the towel away and got in and drove away.
Doc, no access lid on a Wedge.
Platinum
Screw it into the cap from inside and attach the chain IN the filler neck somehow, then. I'll be 'engineering' this for Her MG shortly, methinks.
AngliaGT
Bob,
I did the same thing before going on a car run.
I topped off the oil,set the cap somewhere in the engine
compartment.I drove to a resturaunt where we met for
breakfast,about 8 miles away.
After leaving the resturaunt,I noticed something
shiny on the road.Yep - it was the cap,undamaged!
- Doug
Dale
Me too! I have two spares now, which should assure that my next "big dumb" will be something unrelated. BTW if anyone ever needs one I should have you covered.
Platinum
:lol:
Most CB MGB's seem to carry a "spare" gas cap trapped in the bumper over-rider just below the filler. :smirk:
MDCanaday
The wife's Jag has a magnetic cap that sticks to the cover(or anywhere else)Per haps modern epoxies can be put to use here??? At least the cap would still be stuck to the car when you got home....
MD(mad dog)
Deleted member 8987
My cap (Jag), Factory, Locking.....you can't get the key out unless you re-lock it.
Helps when your ignition key is on the same ring, and you CAN'T drive off until you lock the cap back on
Velcro works fairly well too....
T
Tinster
Almost funny. I have spares and triples of of most parts of my
car that make it operational.
I had no spare gastank cap and wouldn't you know it. Someone stole
it ( I think at a shopping center) I guess I better find a spare.
dale(tinster)
swift6
Similar to this, I have a locking gas cap on my wedge and you have to use the key to relock the cap. So I leave the kes in the cap while it is off.
