Strapping_Lad
Well I have my new alternator in finally and all the positive to negative ground check list done. All I needed to do was put in the points, set and start. Initially the ignition light came on and all was well. Tried to crank it over and would not start. It sounded like it wasn't even trying to fire, just the starter going over and over. I tried to start it maybe 2 or 3 times with holding the key for 3-4 seconds each time. I left the ignition on for maybe 5 seconds and the dizzy started to smoke. There was also smoke coming out of the plug wire from the dizzy cap to the coil and the wire melted that gives power to the tach on the positive side. The wire from the ignition switch is also on the positive side of the coil but did not melt. My points were connected by a single wire to the negative side of the coil. What could be the cause of the points melting?
The coil in the car right now is a Bosch Blue Coil (Made in Germany) looks pretty old. This is the same coil that was running my Pertronix positive ground before I made the switch. There is no ballast resistor hooked to the coil and since it ran the pertronix without one I can only assume it is internal.
From what I can gather, there was a burst in voltage through the coil causing the points to melt, but this would mean the internal resistor in the coil would have to fail as well as the condenser in the dizzy. Would the coil still produce voltage even if something internally, such as the resistor, were to fail?
What did I miss here?
Could the coil have just bit the dust and decided to take my points with it?
I made a diagram of how everything is connected at the moment.
