Bob_Spidell
Side question: At what RPM is the full advance of 35-36deg achieved?
Hi Lutz,
I'm curious how you marked your crank pulley for the 15 and 45 degrees. 15 degrees should be 51/64" (about .8") away from the TDC mark, or 20.24mm.
I wrote my last post before I saw yours.
Are you saying you get a strobe flash at 75mm on the circumference?
Lutz, I think he meant 35 degrees "full advance" in addition to the idle advance setting. I think you mentioned you measured a total advance of 65 degrees @ 4500RPM, so that would indicate to me an additional advance (due to the distributor's internal advance), of 20 degrees. Jim
In computer troubleshooting the rule was always: something's broken or something's changed. Applies to cars too. The Mallory is what's changed. It requires drilling its shaft to pin the Healey drive gear. I wonder if there's a way for it to function correctly with the strobe timing seemingly in the wrong place on the pulley.
I'd want to go back to basics and make sure the Mallory was properly located on the shaft and check the setup for an Austin Healey.
Is the pulley in the picture a stock later BJ8 pulley?
Are you measuring your timing marks using inches or mm? If you are using inches, please check your math. I get 2.5 inches at 38 degrees. If you are using mm, our math agrees.
Lutz,
So the problem appears to have been in your strobe light, but you said you tried the strobe light of a friend that read the same as yours. What's the difference between the Bosch light and the two that you tried?
Lutz,
For instance if I unplug my strobe from the wire it continous to flash until I remove it completely out of the engine compartment.
