Lutz Kramer
One year ago I put a Pertronix Ignitor-I Kit #ML-161 in a Mallory Distributor of my AH 3000 MK III Phase 2.
When I put it in, I did the timing manually, because it couldn’t be done with a timing light since I couldn‘t reach the appropriate paramaters given by the manual, which are 15° BTDC in idle and about 38° at about 4500 rpm. Whenever I came close to 15° the engine stalled. When I checked the timing with the strobe light I got and still get the following indications: 40° BTDC at idle and about 60-70° BTDC at 4500 rpm, which is of course way off. I can’t even believe that the engine is running with those settings.
What so ever the car has been running without any problems since then.
I know the words: „Never touch a running system!“. Nevertheless I want to have the engine running in accordance with the right parameters and of course would like to find out the reasons for this strange phenomenon.
So, I checked the mark for TDC on the pulley while the rotor is pointing at the #1 plug wire. Everything is just perfect! In addition to that, the piston is in combustion stroke and the distributor is indexed correctly and not 180° off.
Now, can anybody tell me what‘s wrong here?
I called Pertronix here in Germany and they absolutely have no idea.
The only thing I can think of would be that the coil ist producing a certain amount of power which is strong enough to create a spark while it‘s not strong enough to activate the strobe. This may be done by a second flow of power that follows the frist one right after. So the strobe would be lighting the 40° mark while the spark is already history???
I know it sounds strange, but has anybody any idea?
Hi Guest!
