My '60 BN7 had been running poorly, making what I'll call a blatting sound on acceleration at low speeds. So I decided to check the timing. Note this car has a Pertronix ignition, and I have never adjusted the timing. With the vacuum line disconnect at the dizzy and plugged, engine warm, my timing light indicated the pulley mark was more than an inch BTD. I turned the dizzy until engine rpm dropped from its ususal 1000 rpm to about 700. The timing marks were thenabout 10 degrees apart, approximately half an inch. It restarted and idled smoothing before I took it for a drive around the community. It ran perfectly. After a few miles, I stopped and let it idle for a few minutes, and then proceeded a short drive home. I noted that the engine was at about 200 degrees (it was maybe 85 ambient), a bit higher than I would expect. As I turned the corner on my street, the engine bucked and the car went sour. Subsequently, I returned the dizzy to near the original mark on its mount, started the car, and proceeded up the street to a stop sign, where the engine bucked and required extra throttle to proceed. I then drove about five miles, the engine running pretty well. The temperature was running at about 200, still warmer than normal, and soon climbed to 212 degrees. By this time the engine was running badly and actually quit coming down my street. Back in the garage, I took a laser temp reading on the header tank, about 212 degrees, and noted no sign of overheating, no activity in the coolant reservoir. After setting for about 15 minutes, I had to use the choke to restart the engine. The timing marks indicated I was about 10 degrees BTD. Rotating the distributor, I found the engine idle stepping up, and locked it down at more than an inch, quite a bit above the 15 degrees (51/64") that I found as the high side on a post on this forum. I haven't driven it yet. Diagnosis?
