TR6 Ignition switch or?
Jerry
Working on a friends TR6, The key is loose in the ignition . wiggle the wires and the ignition lights turns off and on. If you turn it to start, it can get stuck there and keep cranking the starter. Do you think it is the switch itself or the switch part that contains all the wires? Some of the wires appear corroded.
I'm thinking it's time to replace the whole switch shebang!
