sim
Ref 1958 sprite with aluminum head Spark plugs are NGK D7EA WIRES TO THE PLUGS ARE COBALT
DISTRUIBTOR IS pERTRONIX all about 2 years old less than 2 k miles on them
Replace coil ,rotor red one and distributor cap.
also the spark plugs however they were one step colder then the NGK D7EA.
Car started without any problems 2 quick trips a day apart and it started missing again.
I am now thinking the wires to the plugs not so good and need the correct plug. Do not want to replace with same.
Want something better what will work with the Pertronix.
Been thinking of using the copper wire ones and putting a metal mesh over the wire to cut the RF noise that will mess with distributor.
Or should I just go with the magnecor that Moss offers. BTW moss order taker that I talked to knows nothing. Would not even suggest the magencor
Suggestion are welcomed good bad or ugly
thanks
Sim
thanks
Sim
Hi Guest!
