Geo Hahn
...have ordered a cleaned and adjusted one from Moss. If the one I remove can be bench tested and adjusted, I will try that. It would be nice to have a spare.
A spare is good, I carry one on long trips. There are two styles - the early one clamps the wires with screws, the later uses Lucar (spade) connectors. Either can be made to work but easiest to have the correct style for your wiring harness.
I have never adjusted one 'on the bench' - probably possible but I would think it easier to have it mounted and the engine running. You might consider that before removing it.
