Stewart
First issue of the year on the 73 well second if you count the burned out tail light. Noticed that the ignition light is not working. Car runs great tach works normally is there anywhere I should look for a fault or do I have to go through the pleasure of changing a bulb? If it is the bulb which type is it? Any running issues to be expected if it is a dead bulb.
