Spitfire ignition in 78 spitfire
tomshobby
My wife's cousin purchased a 1978 Spitfire. It ran great for a couple days and then it ran terrible, then would not start. I went over and got it running and the next day it would not start. I finally got tired of fooling with it and ordered a Pertronix. Put it in today and now it will not even fire. The only thing I have
find is that it only has 8 volts to the coil. We removed a ballast resistor from the firewall. It seems that there is another resister possibly a resistor wire.
Any help would be appreciated,
Thanks,
Tom
Don_R
I do believe that has a resistor wire in the harness...don't have the 78 wiring diagram on hand..
just a thought, is there 12 volts when cranking. mine was setup to crank at 12 volts and run at 8 volts.
TR3driver
Great Pumpkin - R.I.P
Yup, ballast wire in the harness, in addition to the "drive resistor" on the firewall. You'll need to run a new wire to deliver 12v to the Pertronix; then either fit a ballast between it and the coil or get a "12 volt" coil.
dklawson
You changed the distributor but not the coil... and you removed the ballast resistor? It's not that simple.
See the schematic linked below:
'78 Spit Wiring Diagram Link
The coil wiring is in the top, right corner. The wiring is not simple. The paragraph below is a quick workaround.
The factory ignition system was set up for a different coil and type of distributor. Now that you have invested in a new distributor with electronic ignition go ahead and invest in a new, 3 Ohm, standard coil. Run a white 16 AWG wire from the white wire on the ignition switch directly to coil (+). Connect the Pertronix red wire to coil (+). Connect the black Pertronix wire to coil (-).
Be sure you tape off all the old wires so they don't touch earth and don't forget to set the ignition timing.
tomshobby
tomshobby
Thanks much guys. This answers several questions. He had purchased the Pertronix module and coil from TRF and recommended by Albert so we should be good there.
He purchased the car from some kind of dealer in GA. I suspect this was a problem from the previous owner. The reason is that when offered a considerable lower price they accepted without hesitation and even included transport to WI. The car is nice looking so the original price would have been fair if the car did not have problems.
pipercollins Spitfire Spitfire Ignition Wiring - Story with followup ?'s Triumph 14
C Spitfire Spitfire MegaJolt Ignition? Triumph 0
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
O Ignition switch / steering lock replacement in a '78 midget Spridgets 4
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Help 4
O Sprite Petronix Electronic Ignition Spridgets 10
Ripper01 TR6 Inputs regarding Simonbbc Ignition Solutions Triumph 0
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
T Ignition warning light remains on and headlights come on Austin Healey 8
L TR6 1974 Tr6 ignition switch Triumph 3
H Ignition problem or not ? Austin Healey 11
longbridgehealey Ignition light Austin Healey 11
I General TR Ignition lock barrel help Triumph 1
catfood Looking for suggestions - ignition issue Austin Healey 6
Lin 123 Ignition Question Austin Healey 0
S Fried electronic ignition? Austin Healey 22
6 1965 Sprite Ignition Key Spridgets 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
Drone Dog BT7 ignition timing Austin Healey 5
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
F TR2/3/3A Ignition Timing - Again Triumph 11
S Not sure on the ignition Spridgets 12
Darwin Spitfire ignition wire gauge Triumph 2
W Ignition Warning Light Austin Healey 6
F TR2/3/3A Timing with Electronic Ignition Triumph 14
catfood BN1 Ignition question. Austin Healey 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Drone Dog Ignition light lense Austin Healey 6
B TR6 Pertronix ignition Triumph 11
