MGTF1250Dave
Aloha All,
I have been pondering the low voltage circuitry of my ignition system. In my experience ignition coils come marked either + and - or CB and SW. In the later case, the wire from the ignition switch (white) would connect to the SW terminal and the wire to the distributor (white with black tracer) would be attached to the CB terminal. If a coil is marked + and -, and the car is positive earth, the ignition switch wire connects to - and the distributor wire connects to + as it is the path to ground.
A. I have also read and been told that if the car is converted to negative earth, the switch wire should be moved to the + terminal and the distributor wire should be changed to the - post. Is this correct?
B. I've never dissected an ignition coil, but this is what has me questioning distributor wiring described in A. The voltage input from the ignition switch is the source of power for both the primary and secondary coil, the path to ground for the primary coil is through the distributor via the CB terminal and the secondary coil discharges to ground at the spark plug. It would seem to me that internally, the coil terminal SW connects directly to both primary and secondary coils and the CB terminal connects only to the primary coil. Does this sound reasonable?
C. I have never seen an ignition coil labeled as either positive or negative ground. If my assumption in B is correct, it would seem to me for best ignition performance the switch wire needs to be connected to the common feed to both internal coils and the distributor wire needs to be connected to the ground for the primary internal coil. With coils labeled only with + and -, how do you determine this? Or, does it make any difference?
