I have fitted an electronic distributor brand 123, with vacuum advance, I have tried to find the Lucas advance curve for the 25d6 original distributor with no luck so far. In the healey manual it states the advance is 35 deg. at 6400rpm , as the red line is around the 5500rpm I am very reluctant to rev the engine to 6400 . So the advance curve can tell me, say, what the advance will be at 4000rpm, a much safer limit, also how often would a driver sustain revs above this on the open road, Also on reading the advanced search section , have found conflicting advance set numbers, eg. some say no8, some 5 one said f. I feel the only way to check this would be to check the 123 against the original and safe rev range and adjust accordingly . can any one help here? Saltiga
