[ QUOTE ]
K...what can you tell me about the model of the one on eBay...seller isn't providing any additional info or photos, so far...
[/ QUOTE ]
Looks like a DB18 Consort. I think its the same chassis and engine as in my Special Sports, in which case performance is underwhelming (don't buy it if you are at all interested in performance). It uses as pre-selector gearbox (you select the gear you want, then press and release a "selector pedal" to change the gear (it is in the place where a clutch pedal would be). It also uses a fluid flywheel to transfer power to the gearbox. It is a very simple version of a torque converter that is filled with simple 30-weight oil. The result is a very smooth shifting car that will cruise nicely at highway speeds, but which has rather lack-luster acceleration. Brakes are "interesting" as well. Mine are mechanical in the rear and hydrolic in front. Not sure about the Consort brakes, but probably the same.
