I'm getting a whine or buzz, which seems like gear noise and sounds like it's coming from the transmission area. It's loudest around 3000 RPM in top gear but seems to correlate with road speed, not engine speed. I think I know what's happening, but before I tear the car apart, I'd like to get some insight from any of you with more experience in tracking down this kind of problem.
The car is a newly restored solid-axle TR4A; just got it back on the road in August. I rebuilt everything in the drivetrain.
I've made the following observations:
1. The pitch of the whine does not change when I shift gears and keep the road speed constant.
2. The pitch also doesn't change when I switch the OD in and out, as long as I keep the road speed the same.
This seems to rule out the transmission and OD; the noise would have to be from the differential, drive shaft U-joints, or output shaft bearing of the OD. But the sound seems to come from the transmission, although I realize that sounds can be hard to localize--maybe the transmission cover just transmits sound better than the body of the car. I've never heard a U joint make a noise like that, especially a new one, and I spent quite a bit of time and effort getting the differential right when I rebuilt it. I reused existing OD bearings, but I inspected them closely. Nevertheless, it seems like the differential is the most likely culprit. I also wonder if it might just be a vibration, but I can't imagine what might vibrate and make a gear-like whine.
So, does anyone have any more thoughts on this, or can anyone suggest more tests I might make?
