Thor
I think I have reached the bottom of my knowledge on what the next logical step might be to address my 1975 1500cc overheating while under a load or at high speed for any distance.
This is what I have done so far: Added a new radiator from Moss. I checked the % of coolant and its at 50%. I've checked the fluid levels and they seem ok. The timing is set at 12 degrees BTDC as the motor is from a spitfire 1978. I added an electric fan which cools it once I have reached grade or am traveling under 40mph. I even have switched from the plastic pressure tank to a 1275 brass one thinking it might help as I saw in Moss a reference that the 75 had heating problems which one of the modifications to correct was adding the old brass tank back. I also moved the front plates so it didn't block the air ducts. The spark plugs are a nice brown so I don't think its running lean either.
The new radiator has both the inlet and outlet at the very bottom and I have heard this is part of the problem along with needing more rows to add additional cooling capablities. Is the next step to take. I would appreciate any suggestions as to what might I be missing, Thanks
