hi there,
anyone out there knows what is the correct fuel pressure i should expect from a fuel pump to be able to feed two dellorto 40 DLHA carbs??? please let me know what electric fuel pump can work for these carbs and were you suggest is the best place to hide the pump considering that i need lots of preasure for the two heavy gas drinkers /ubbthreads/images/graemlins/eek.gif.
I do want to leave the original fuel pump, but do i have to cut the little arm that connects to the camshaft? or should i leave it? /ubbthreads/images/graemlins/confused.gif Will the work simultaniously? Common sense tells me that the original one will obstruct the new one, which makes me wonder what to do with the original one? please let me know what you would do.
i also want to buy a fuel pump that would work with the stromberg or SU (1.75 inch) carbs in case i ever want to save TONS of money on gas.
As always your advice is bienvenido - meaning more than welcome /ubbthreads/images/graemlins/thumbsup.gif.
thanks .... Paul
thanks .... Paul
Hi Guest!
