Nunyas
So, there I was, replaced the speedo cable on my B, that works most excellent again. While I was at it, I replaced the courtesy lamp on the center console; the amount of light that thing emits is nearly obscene now. I installed a radio blanking plate, the quality of which I was impressed with. For the price I paid, I was half expecting it to be made of plastic, but this thing was an all metal 3-piece deal. The MG badge was chrome plated metal, the black backing plate was black painted metal, the chrome trim ring that goes around all of that was metal, and the fasteners that hold it all together is metal as well. but then, i digress...
Anywho, the odd thing is, when I finished all that, I decided to look into an 'odd' miss that I've been experiencing lately. I started with the iggy. Pulled the lead from the coil found the coil side to be lookin' nice, but the dizzy cap side needed a little love. So, love it received. Then I started pulling the leads to the plugs, all of which appeared to be in good nick. Finally, I started pulling the plugs, 1, 2, and 4 looked good, and light'ish tan color to them. But #3, that one had an obvious "i'm too lean" white'ish color to it. This strikes me as odd, because the plumbing for the gulp valve puts the air in-let closer to 1 & 2. In the past, 1 & 2 have always had a slightly more lean appearance to them. This weekend however, #3 appeared to be much leaner than the rest of the cylinders.
What do you guys think about that? I'm currently considering getting new plugs, leads, and dizzy cap; the ones on the car are about due for replacement. You guys have any thoughts or ideas as to why cylinder #3 would have an much leaner look to the plug than the rest of them? Blockage in the intake path maybe?
Hi Guest!
