bt7tricarb
I am on a trip w/limited access to the internet, but I will check again tomorrow to see possible solutions.
The details:
- Car was running fine until I washed the car (including engine bay) the night before the trip (Sunday).
- On the drive home after the car wash I noticed it started kicking and bucking. I figured that I must have gotten some water somewhere it wasn't supposed to be. I took some compressed air and blew out the distributor cap.
- Car fired right up the next morning and ran just fine around town (bank/post office - about 15 miles) before I hit the road.
- Once on the road, the car would get up to speed and then shut down. I'd pull over into the emergency lane, but before the car would stop rolling, it would fire right back up and get back up to speed.
- Repeat this for a VERY frustrating 40 - 50 miles. (Considered turning back home, but I figured I might still have water somewhere)
- Problem seemed to clear up after almost 100 miles and calls to your most trusted repair shop (Hendrix Wire Wheel for me) and they have me check coil wire and fuse box. Convince yourself it was water somewhere and it's finally resolved. Go about 300 mile.
- Problem seemed to return, but not nearly as often.
- Now, at destination, car seems to run fine in town, but then on highway, get it up to speed (55 - 75 m.p.h. depending on overdrive, but usually around 3000 R.P.M.s) car cuts off. Electric still working (ignition light comes on if clutch is depressed sometimes, but not always. Sometimes, if clutch is depressed, it goes down to "idle" R.P.M. running "rough," but after a couple of seconds it "clears" up). But again, "coast" down to 45ish, and if ignition light comes on with clutch depressed, pop the clutch and the car will fire back up.
I talked to Hendrix Wire Wheel and consensus seems to be it is fuel related - not getting enough fuel when carbs are under full "load." Upon advice, I checked the fuel filter up by the carbs and it seemed dirty so I found a local auto parts store and changed it today (and yes arrows are in correct direction for fuel flow). Again, car seemed to run fine locally for a while, but tonight on the highway the starting/stopping problem returned. Finally, tonight, it even seemed to have the problem near the vacation home (in town).
I will be back in touch with the folks at Hendrix Wire Wheel tomorrow, but I'm looking for additional possible solutions. My drive home (400 miles) is only a couple of days away (Saturday) and this has got me pretty scared.
A couple of additional notes:
- Even though I try to avoid spraying certain areas, the fuse box on the firewall did get a little wet, but fuses are all in tact.
- Other than the overdrive not wanting to engage a couple of times, no electrical problems at all (and overdrive not wanting to engage always coincides with the rough/underpowered running).
- I've checked and double checked the spark plug and coil wires.
- I've got electronic ignition.
- Can't hear the fuel pump when on highway, but hear it clicking away just fine when I first engage the ignition.
I'm at a loss, otherwise. I just don't know what to think. Like I said, car ran great before the last car wash, but certainly any "water" problem would have cleared after 600 miles of driving over three days, a new fuel filter, and about three/four fill-ups.
Any other ideas?
The details:
Any other ideas?
