I need an oil with a really high flashpoint
G
Using it for casting so lube pro[eries aren't a concern. Anyone know of a readily avalaible and hopefully cheap oil with a high flashpoint?
Readily available...Will non petro oils work?
All I could find was a smoke point chart, which is not the same as flashpoint, but could point you in a direction. Hope that helps. Lookup Freeman Supply in Ohio. I use them for silicone/resin casting stuff. I think they have foundry supplies too.
