The story of my life,it seems -
Took the GT to a local shop,due to a leaking rear main seal.Figured It'd take me
over a year if I did it myself,& I could be driving it soon instead.
Turns out that they found a few major things wrong (that I probably wouldn't
have found,so the bill was a lot more than I had planned on.
When I got it back,it still didn't run right,due to a worn distributor,& a bad crankshaft,
so now will need to spend even more money,as it needs to be fixed.I've been feeling really down
about this,& am actually considering selling it after it's fixed,& possibly going another direction.
Then the "CHECK ENGINE" light came on on the Miata.It came on once before,& cost me $60
to put it on a (good) scanner that told me it was a switching solenoid that cost $110,but was able
to replace myself.Now the "CHECK ENGINE" light's come on once again.It will also need two new
tires at some point,as I got a flat that was unrepairable,& am using one of the used tires that I've
kept around,but is about 6 years old.
Then my '94 Dakota 4WD had it's "CHECK ENGINE" light come on also,& I'll need to be buying
tires for it pretty soon (more $$$).
Is this some kind of virus,&,id so,where does it end?
Hi Guest!
