AUSMHLY
Hello all,
I am having some problems with my HD8 carburetors.
After a very good cleaning, I found that one of the pistons went into the chamber and got stuck. In trying to pull it back out, it scored both the chamber and the side of the piston. After some sanding with 2000 grit, I got it back to smooth and back together. Now the piston moves and seems like a tight fit, but maybe the tolerance is off?
I put everything back together with the help of my Healey mechanic. We also replace the points in the distributor with Pertronix .
My mechanic is not happy with the way the carbs are running and I too notice it. He is not sure if they need more adjusting or if my bad in scoreing the inside of the chamber.
What to do?
Maybe replace the one chamber and piston?
If so, where can I get one.
Or maybe send mine out to someone or the entire carb set up, as in the entire both units?
Also I notice when starting the car, it does not start as quickly as with points. With points it used to turn 2-3 times and start. With Pertronix, I turns 7-8 times before starting. And sometimes after 3-4 times turning over, when I turn the key back to on position the car starts. I did not know it was going to start, so I was going to do it again. Know what I mean? You think it isn't going to start so you turn the key back, then the car starts.
OK, guys, I'm sitting down.
Roger
What to do?
Roger
