Nunyas
I let some smoke outa my wires today... Turned onto my street and the car acted all 'wonky' when i mashed the gas pedal. So, I looked down and immediately notice the charge light had a medium'ish glow going, and then I noticed the smoke was excaping from the steering column cowl! By all recollections I would gues I released a good 1/4 to 1/2 oz of the stuff.
She's my daily so I had to do the trouble shooting and repair pronto. I took the column a part and couldn't find anything amiss. I put the keys back into the ignition and turned the power back on. While looking at the column for where the smoke was coming from i noticed that I was in silence; complete silence. I have one of those Facet fuel pumps that *never* stop making noise when the power is on. So, I figured I'd better check out what's going on back there. With the power still on, I went into the boot. I moved my tool box out of the way and bumped a wire in the fuel pump access hole area, and the pump sprang back into life. I said to myself, "hmmmmmm... odd, what's this wire here? OUCH! that thing is HOT!" Apparently, an over looked wire found ground back there when I hit a bump today. Some Snip Snipping and a little tape later, I had the car restarted the car and ran through op-checking all of the electricals. All the electric goodies were working fine again and the engine was no longer acting 'wonky'. So, I guess all's good again, sept I need to put 1/2 oz of smoke back into me wires...
Any one got a good source for the good stuff? Also, where's the access nipple for injecting the stuff back in? /ubbthreads/images/graemlins/jester.gif
