jlaird
There is a bolt/cap cover that goes on the out side of the over oil pressure spring at the rear right side of the engine.
I have one that has had a hole drilled in it and taped. There is a screw through it with a lock nut, on the inside is welded a plunger that would allow you to compress the spring thus increasing the oil pressure pop off protection.
Any clues guys, I have never seen anything like this before, have you? /ubbthreads/images/graemlins/hammer.gif
