KLUTZ
I removed the 25D distributor from the '71 on Monday to check the points and condenser on it. I had been having problems with slight jerking and holding back at 60 mph on the highway. At 65 mph, it ran fine. My wife also had a problem last weekend where the car wouldn't go above 2500 rpm.
I ordered the parts from my mechanic but remembered that there were brand new points, condenser and rotor on the spare 25D Dizzy I took out of the 74.5 engine. I thought I would just swap them until I saw a crack in the side of it.
I took off the equiptment from the usable Dizzy and cleaned it up. The rotor was a little worn, and there was a lot of rust on the rotor stem. I sanded that all down. I then removed the points and condenser from the spare and screwed them down in the exact spot the others were in. I then put on the new rotor, installed it back in the engine, capped it and hooked up the wires. The car started immediatly and idled great. I took it out for a good run and I had none of the problems I had experienced prior. Pick-up is also remarkably much better. The car is REAL fun now. I also noticed last night that the car does not run-on for the 5 seconds like it was doing before. It doesn't run-on at all now. /ubbthreads/images/graemlins/smile.gif
What is the problem?
A co-worker asked me if I gapped the points when I put it in. UH.. No I didn't. Didn't even know I had to.
should I take it apart again and "gap" them? and how do I do that?
Or... did I maybe get lucky and set it up perfectly?
Thanks in advance again.
Paul
Paul
