Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Jack,
Is it bound up because you pushed in the clutch and it did not roll or you put it into nuetral and the car did not roll? How do you know it is bound up?
Cause it is 1/4 inch shorter from front to rear than the orginial.
It also will not move much when the peddle is pushed when you look up inside, buddy pushed. It kind of bottems and refuses to go down past about a half.
