AUSMHLY
tahoe healey said:The mfg should not matter. They should be gaped at .025 plus or minus .001. Checking the color of the plugs will tell you if you are running one carb richer that the other. Also listen to the exhaust for even soft tones.These are easy things to do before spending money with your mechanics.
Hey Rich,
Here's where the discussion has now turned to.
.025 for the Lucas regular coil?
.035 for a Lucas sports coil?
I need the Lucas sports coil for the Pertronix, that's a given.
By the way guys, I just filled the tank and I averaged 12 mpg (town and freeway driving) (points at .025).
Let's see what I get with a set of new plugs at .035
Cheers,
Roger
Hi Guest!
