Hydraulic Tank
Wausau 911
Still sorting the BJ7 out. My dual outlet tank leaks at the top cap and has been a continuing issue for some yrs. the seal seams in good order and the cap is fairly new, but I get leakage. No rust on tank lip. It is quite humid here, but I doubt this should be occurring. Anyone else have this issue?
thank you for all replies.
British_Recovery
Bronze
There's a different seal available, that I'm currently using. Dorman HELP! Part # 42072 on line (Amazon) or Pep Boys auto stores, among others. I cut a small slit in the center section. This seal keeps the fluid in the reservoir, and I don't overfill it. Leave room for expansion. I was getting some fluid out onto the body work from expansion, so also made a loose-fitting cap out of a spray can lid, cut to go around the mounting bracket. Allow space for air to get in from below and drill a few holes on the side. Can't go anywhere with the hood closed.
Brinkerhoff
You must be overfilling it. I keep the levels only slightly higher than the inner (clutch) chamber. Mine has never leaked a drop in ten years.
Duane_Rhynard
Moss has a seal that theoretically solves this common issue. Part number 582-505, they have info on their website about it. I've purchased one but have not yet put it in service....
Their description:
"We also changed the cap gasket from a simple flat ring of rubber to a complete cover. (Fig 7). There are two reasons: First, we were aware of an annoying tendency for brake fluid to squirt up out through the vent in the cap. This is especially true of the Girling caps (and replacements) which have the two vent holes in line with each other. We off-set the vent hole on the inside with this in mind, but the "anti-splash" seal makes it impossible for fluid to escape. The second reason for using this type of seal is to limit the amount of atmospheric moisture that can get to the brake fluid. There is a tiny slit in the seal that will allow air pressure to equalize as needed, but the seal greatly reduces the exposure of brake fluid to moisture. This will effectively increase the life of conventional brake fluid, and help reduce the damage water can do. (For more information on this topic, see our website for the article on brake fluid). "
Healeysince59
That's a Chevy part but it's out of sight so no one will know. I've got them in all my LBCs. Be sure you make a small slit in it so the tank can breathe.
Marv J
GregW
A man of Dave's character I can only imagine as doing well. I had saved the couple PM's of his I had, but unfortunately they were lost when the forum software was changed.
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
JimLaney hydraulic line material Spridgets 6
J Hydraulic Brake Switch Internals Austin Healey 19
I General TR Hydraulic lift opinions/info needed Triumph 34
C Bleeding the hydraulic clutch Spridgets 6
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
M 948 clutch hydraulic line Spridgets 7
catfood Hydraulic cylinder repair. Restoration & Tools 2
texbears3 TR4/4A Hydraulic Fluid Contamination Triumph 10
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
GBRandy Wedge TR8 Hydraulic lifters - Replace? Triumph 1
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
Lin 4-post lift hydraulic fluid Austin Healey 5
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
TulsaFred Hydraulic system disassembly-reassembly Spridgets 10
M TR2/3/3A TR3A Hydraulic system problem Triumph 4
Moseso Weird Hydraulic Failure Triumph 8
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M Hydraulic Problems Spridgets 5
I Bugeye hydraulic problems Spridgets 9
JohnnyMead Another Hydraulic Fluid Reservoir Question Triumph 10
angelfj1 Paint Quality - Hydraulic Fluid Reservoirs Triumph 14
R BE Hydraulic Question Spridgets 15
Ohiobugeye Another Clutch Hydraulic Line Question Spridgets 2
ekamm New hydraulic resevior Triumph 5
Ohiobugeye Got Engine Running, But have Hydraulic Leak Spridgets 2
Ohiobugeye Hydraulic Bleeding Sequence Spridgets 7
F Dirty Hydraulic Fluid Austin Healey 7
bluemiata90 CLUTCH HYDRAULIC HELP Triumph 9
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
S Hydraulic Brake Switch Austin Healey 5
knad2208 Hydraulic Clutch Fluid Spridgets 1
F Hydraulic clutch adjust Triumph 9
Tinkerman Brake and Hydraulic lines Triumph 4
S hydraulic lines to seal Triumph 4
philman hydraulic lifters Restoration & Tools 5
M Hydraulic brake light switches Jaguar 2
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
Baz Teflon tape on hydraulic lines? MG 7
mrsprite Clutch hydraulic woes Spridgets 32
G Bleeding the hydraulic clutch Spridgets 36
martx-5 Clutch Hydraulic Pipe Routing Triumph 5
regularman British brake hydraulic fittings? Spridgets 9
71tr clutch - hydraulic throw out bearing Triumph 13
