angelfj1
Before you run out and buy one of those new hybrids, you might want to look at a diesel.
hybrid or diesel
hybrid or diesel
NutmegCT said:....
I've even heard from reliable sources (!) that a Corvette gets over 30mpg in highway driving.....
coldplugs said:[
Here in cold weather country I imagine that using the heater must keep a hybrid's engine running, no?
swift6 said:I've long held that the best "hybrid" would be a diesel electric. Small, sub one liter, diesel running at a steady rpm generating the electricy for electric motors at each wheel. The concept works exceptionally well for moving trains. HAve read some rumors lately that VW, for one, is working on just such a car.
tomshobby said:I have had excellent experiences with diesels and do hope they come back.
That said I agree with Tom. In 1996 we purchased a new SW2 Saturn wagon. I had a trailer hitch installed and we loaded up our trailer and left on vacation to Missouri and Arkansas touring and trout fishing. We did not try to drive conservatively and even "tested" the acceleration in several instances. We averaged 35mph on the trip. Still have the car, it has about 120k miles, and it still gets in the mid 30's for mileage. It is also paid for. I have trouble figuring how a hybrid would save me money.
As for our TR6, we really enjoy stepping on the gas while we pass those hybrids. With a big smile on our faces!
sparkydave said:Gotta love the older Saturns. I had a '97 SL2 with a stick shift that regularly got 38 MPG on the highway. Even at 128,000 miles it still ran like a champ.
The gas engine will run more in the winter on a Toyota hybrid. It will start and run until it hits a certian temp, then shut off until either temp, or electric supply command it back on. But, the newer Toyotas also use cemic heaters that run on electricity to augment the traditional coolant heat.SilentUnicorn said:coldplugs said:[
Ya know i was wondering the other day how folks in the prius keep warm when they are running on batteries?..
mark
DNK said:Yea ,but those are english miles.
Sorry to dig up an old thread but I saw this and thought I could add something.Banjo said:The gas engine will run more in the winter on a Toyota hybrid. It will start and run until it hits a certian temp, then shut off until either temp, or electric supply command it back on. But, the newer Toyotas also use cemic heaters that run on electricity to augment the traditional coolant heat.SilentUnicorn said:coldplugs said:[
mark
DaveatMoon said:The record for one tank in an unmodified car is 116 mpg, which was set driving back and forth over a weekend in August (<span style="font-style: italic">multiple drivers taking turns</span>) on a very busy 4 lane road in suburban Pittsburgh. It took more than 1.5 days to burn one 11 gal tank of gas!
DaveatMoon said:Once it's up to temperature the Prius has what is basically a big thermos bottle that is filled with hot coolent every time the engine shuts down (in motion or when shutting the car off). The heater draws heat from that bottle. Long before that bottle cools the engine cools to where it needs to kick back on anyway.
In practice there is no interruption of heat under any circumstance.
