Jim_Gruber
So I cured my rubbing issue on the hub and wheel cylinder with some tender touches from the Angle Grinder, thanks Rut. However with the nut cranked down as tight as it can go on the axle there is a definite wobble to the hub. I can place my hands on the hub and there is a tiny bit of play there. So guys do I put it back together, install the axle and just see what happens. The bearing face on that side was pretty torn up with some pretty good gouges and the Speedi Sleeve pounded all of the way down until the tear off strip was even with the end of the thread. Should I have pounded on the Speedi Sleeve further. Before I close it up I need some guidance. Don't know what the gap is but I'll bet a feeler gauge can possibly measure. Setting up a way to really torque down the big nut but even after I tried that. May not be 140 lbs but I'll bet at least 100 ' lbs clamped down on my utility trailer. Still moving less but still wobbly. Thoughts Team?
