G
I've got two sets of carbs that need equal amounts of work done to them and I'm trying to figure out which set to build. Both need shafts, SL (spring loaded) needs jets and needles. I'm unsure if the fixed needles need replacing. From wht I've read, the spring loaded type needs the needles replace every 50K or so. That I don't like. I'd rather not have to replace needles if I go to the trouble of tuning them out.
I need to keep a set to convert to injection later on.
Which is the better carb?
