G
Moss shows throttle shaft bushings for HS2 and HS4 carbs. Are these factory installed, or do you have to ream your old carbs to accept them?
Hi Guest!
DrEntropy said:Shaft bushes don't much care about pump delivery pressures. It's more about vacuum demand!
RickB said:2 to 3 psi = ok
5 to 6 = not ok
some have to be reamed and some do not
kellysguy said:DrEntropy said:Shaft bushes don't much care about pump delivery pressures. It's more about vacuum demand!
Two unrelated questions in one thread. I have sloppy shafts and I'm debating if I should send them off or do it myself.
