HS2 carburetor question… now with video!
jehuie
In the process of rebuilding two of these. One snaps closed quickly as I think it should. The other sinks down more slowly. But is this ok? There is no damper oil yet which should slow both of them down more. All I did was clean them both up with acetone.
Platinum
Check that the needle in the "slower" one isn't rubbing in the jet as it lowers. Sometimes the jet can be a bit off center.
Should both drop with a definite "tunk".... (tech term 😉)
jehuie
jehuie
Thank you for the fast reply. Unfortunately, it slides down significantly slower that the other even when just sliding it inside the removed damper pot. Or with the needle removed. Not sure why. I think it must have been that way before I disassembled it. Maybe a mismatched dashpot?
Platinum
Quite possible. No knowing how many hands have been into the car in its lifetime. Try swapping the tops? That could have happened at some point. Not all folks know (knew) they were somewhat matched to the pistons.
Still consider the jet centering in the "slow" one as well.
jehuie
jehuie
What is the technique to be sure it perfectly centered?
jehuie
jehuie
Also, I saw a rebuild of a slightly different model that had tiny springs on the jets. This one did not and neither did the kit. Is it supposed to? And how far into the hole should they be when I screw them in? I put them all the way down.
Platinum
They (neeldles) should be in the pistons with the shoulder flush at the surface of the piston. Almost hate to suggest it, but there's a tool that substitutes for the needle to center the jets. A kit I've not been able to find on the 'net now.
Stand by, I'll hunt further.
Platinum
Springs are in the "emissions compliant" SU's. Yours are pre-emission. No springs.
jehuie
jehuie
That is how I put the first one in. But when I disassembled the 2nd one it was recessed all the way down so I figured that must be right and changed the other to match. Glad I asked. Even more glad you told me!
Platinum
That link I posted has a really comprehensive explanation for setting up the carbs.
jehuie
jehuie
Got it to go clunk! Thanks for the help. It is still slower to talk than the other one. But that happens even with the needle fully removed.
XJtom
do you have digital verniers, looking at your video the slower piston looks like it has minimal air gap to the other, perhaps just measure the piston and compare diameters, the larger size will drop slower, want to make it drop faster? just use W&D paper fine and hand sand it.
BobHaskell
With the transfer holes taped closed, the piston should take 3 - 5 seconds to drop. See Burlen's web page on rebuilding carbs.
jehuie
jehuie
Thank you again everyone. I was able to get both carbs to close properly with some adjusting and things look good on them.
But now onto the next issue!
When I run the car, the back carb has a lot of flow. I can put my hand up to it and feel strong suction. But the front carb has very little flow whether it's idling or running faster. I checked and the butterfly valves on both are operating together correctly. If I take the carbs off the car and turn it over, there seems to be good suction on both sides. But when the carbs are in place it is still extremely lopsided.
Have I done something wrong or is it just a matter of adjusting them now?
XJtom
what is the reading on a vacuum gauge for each carb, if you don't have the tuning type gauge to fit intake of carb i use a standard vacuum gauge which i attach to the carb in front of the throttle or after it which ever is available.
jehuie
jehuie
Unfortunately, I have the carbs off still so I can't measure it at the moment. I didn't put them back on yet in case I did something wrong with them and need to fix that before going on. I may just re-install them though and try again.
jehuie
jehuie
turned out that I had a vacuum leak along the heat shield. I put some sealant on both sides along with the gasket and things are greatly improved. But I think I still haven’t gotten it quite sealed all the way. What kind of sealant do you recommend in there?
XJtom
what sealer did you use? not sure if this product is available your way - i use permatex "non hardening" easy way to find the leak is to spray water (mist) on suspect areas, when it changes revs you know you found it.
Platinum
For years we've used Hylomar blue for a sealant, impervious to fuels and remains semi-solid. The water mist is a really reliable way to determine where a vacuum leak is located, too.
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
58Custom SU HS2 Piston assy movement-- question Spridgets 20
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
