Woodie
I have on my 70 midget twin SU's. ON the rear carb there a hose going from the carb to the 'cannister' under the water pump. The front carb does not have a hose or even a fitting to attach one. While doing some research I found this picture from a 78 midget. It shows both carbs with a hose that is plugged. There is no cannister either. my question is, is there any harm in leaving the rear carb connected, or can I plug this as well, but if I do what do I do with thehose to the canister. By the way what does the cannister do?
Hi Guest!
