Cain
OK. I've got all the parts I need for the TRF type spring compressor. Now I'm just wondering exactly how to use it.
I've got the old springs off and need to put on the new springs.
It seems to me that I run the all-thread through the hole at the top that the shock thread goes through and put washers and a nut there. Then I place the spring and lower spring plate on the all-thread. Then run the disk with washers and a nut up under the spring plate to hold everything in place. Then - while praying - begin to compress the spring by tightening the nut under the spring plate. Once the spring plate reaches the lower arms, attach the plate to the lower arms and remove the compressor.
Is this even close to correct?
Thanks,
Thanks,
Hi Guest!
