rkep01
I know this has been discussed before, but I don't seem to be able to find it. How do you determine when lever shocks need rebuilding? Just took all the shocks off my Bugeye and found that the rear shocks are quite stiff when I move the lever. They both will travel the full distance, but it takes considerable effort. The front shocks have resistance to movement, but are much easier to move, requiring only moderate effort. Should the fronts and the rears be the same? Or is it normal for there to be a difference? :confuse:
Hi Guest!
