Hello Doug,
"There is no substitute if you need to solder to steel."
I have always been able to use standard resin cored electrical solder to tin steel, not acid fluxed. There is also 'solder paint' if you need to do a lot of soldering as in lead loading. In case you are not familiar with it is a paste of flux and solder that you brush onto bright steel, copper etc and heat up and wipe to leave the surface tinned.
Alec
Alec
