Shealey
I'm starting the disc brake conversion on the Shealey. I need to separate the wishbone from the swivel pin. I need to use the swivel pin with the disk brake caliper mount.
Q.) If I remove the 5/16 nut on the locking that goes through the middle of the swivel pin, will the fulcrum slide out?
Here's a photo of the wishbone and nut on the swivel pin.
Q.) Is there anything else I need to do to get the fulcrum out?
Hi Guest!
