How to get a good seal around side windows BJ8
AUSMHLY
Hi all.
I thought I'd post how I got a good seal around the side windows of my BJ8.
First your top should fit as good as you or your top installer can get it. And that is a feat in and of itself, so good luck!
You've adjusted your side window glass to follow as close as possible (gap and uniformity) to the out line of the top area. Now it's up to the rubber to seal that gap.
First I'll address the bulb rubber that is used along the side window.
I found the original rubber seal from the 60's still on a top frame I bought. The original bulb is about twice the size of what's available now from our suppliers. The ones Moss sells has a stiffer rubber than the Bristleflex brand MacGregors provides. I choose the Bristleflex for the softer rubber, however, his bulb is smaller than Moss's. There may be other brands available, but being I don't know who else has them, I could not compare theirs.
1. I found water leaks in at the top front corner, where the top meets the windscreen post.
If you look close at that corner when the side window is up, you may be able to see light through that area. Some tops don't have a problem there, but no matter how many times I repositioned both the header rail retainer and the side cantrail, I could not get the rubber bulb to seal the triangle area where the top meets the pillar post, vent window and side cantrail. The rubber seal should be one long piece, that starts at the end of the side wood that is over the side windows, then curves at the windscreen piller area onto the header rail. It continues to the other side, curves again at the pillar and continues to the end off the other end of the side wood. What I ended up doing to eliminate that gap at the pillar post was to move the side cantrail out closer to the edge of the top side wood. Because of that, the header rail and the side cantrail did not line up enough to use one piece of continuous rubber. I cut the rubber into three sections. One for over each window and one for the header rail. Now the side rubber bulb would run right up to the windscreen post and make seal.
2. Second water leak was at the top of the vent window, around the rubber tip.
Because of the thickness of the edge of that rubber tip, it created a small gap between the thickness of the door glass and the edge of the vent window where the rubber tip is. To close that gap, I moved the side cantrail out further, which put more pressure against the rubber bulb where the rubber tip is.
3. Third area was at the rear curve of the side window where the two rubber bulbs meet.
I found that a) the rubber end caps don't follow the same outline of the rubber bulbs and b) once glued on, they did not compress a easy as the rubber bulb. It would be at that place that water would find a gap. What I did was to install one long piece of rubber bulb, and make a straight cut at that hinged area. I held each end in place by putting some dum-dum behind them. Now when then the two rubber bulbs meet, it's like it's still one piece of rubber bulb. Both pieces compress with the same pressure and there's no raised rubber or harder rubber to compress like the end caps introduced.
This page will show photos of where the top meets the windscreen post.
Second page will show photos of the vent window rubber tip and where the two rubber bulbs meet at the curve.
Now for the purists out here, you bet it's not correct and you don't see any end caps. However when the top is in the down position, one does not see any of the end caps because the top has the stowage cover on.
For the non purists, it has a much cleaner look and my car is actually water tight. I don't drive in the rain, but I may get caught in it. However I do wash her all the time, and that's when I found the water would leak in. I may have one of the very rare Healey's that stay dry inside when it's rained on, by my garden hose. I know what you're thinking, now that's just not British.
Cheers!
Re: BJ8 converible top leaking around side windows
1. Photos of the vent window rubber tip area.
2. Photos of where the two bulbs meet area. First photo shows how it was with the rubber end caps.
Photo of the complet top
As usual Roger, great detail work. The top, seals et al look super. Fit looks terrific.
I really like my roadster better - except when I have to put the top up and down, and drive in the rain, oh, and bolt on the side curtains and listen to them rattle. In those conditions the convertible is just sooo much nicer.
Great job.
Lin
Hey Lin,
Nice to hear from you.
Guys, you should see what a great job Lin did with his restoration. I'm jealous.
Why don't you post a photo of your car with that beautiful hard top. Healey's are one of the few cars that can pull off a hard top, and Lin's car is one of the very best of the best!
I'm happy to say, no window rattle, no top squeak sounds, no wind noise, when driving. When closing a door with the windows up, the top will balloon up for a second, from the air pressure. And it only took 9 months to figure out how to get to that point. Ah, good times...that I would not want to go thru again :smile:
Cheers my friend!
Roger
I will be having another look at my soft top later in the year, ( it has been removed again to hopefully fit the new drain channel after I sort the passenger floor and sills) It did keep the rain out last year at Goodwood, though it did not rain much, I will see if I can repeat that sucess again.
:cheers:
Hi Everyone,
Thanks for posting these details on your installation, Roger. It's beautiful! It would be great if anyone else who has successfully installed a top would share photos too.
I'm in the middle of doing an installation on my BJ8. I bought the car with the top in pretty rough shape, torn and missing a lot of pieces. I'm trying to figure out how to get it right. One of the areas I'm having trouble with right now is how all the bits go together on the front bow. In particular, there's a small seal, #11 in the diagram you posted at https://www.britishcarforum.com/bcforum/u...dow_adjustment. I assume that fits around the metal header rail seal retainer and is then covered with top material separately. But I don't know exactly how it's all put together. Any advice would be helpful on that.
I'm sure there will be other issues as the job proceeds. But this and other posts have been really helpful. Thanks again and congratulations on a magnificent installation, modifications and all!
-Dave
Hi Dave,
I just bought the Moss CD on interior installation, done in 1987. It includes installing the convertable top too. Just thought I'd mention it if you didn't know. Its kinda pricey at $70, but since I couldn't find it used, and I'm about to do a full installation, I bit the bullet. I just viewed it, and though it is a really old video I think it covers the top fairly well. I don't know much about these tops really since I have only removed my old one and disassembled it.
Good luck with your top.....Jerry Rude, BJ8
