Nope, it's a plate that blocks the sliding member from being engaged.Bob Claffie said:My second AH was a 100/4 that I converted the stock gearbox from 3 sp to 4 sp. I have different thoughts from the majority. I used the car for autocross and never had a problem. There was never any thought to change the rear gear since with the OD it would go close to 100. As far as stress and strain nothing ever went wrong in the tranny or rear. <span style="font-weight: bold">Memory is vague but I seem to recall that there wasn't a plate in there to remove but a "boss" that had to be ground down to access the hidden gear, then again maybe not.</span> Bob
Hi Pan,pan said:Re axle ratios: I believe the 100S sales brochure offered final drive ratios of: 3.6, 2.9 & 2.6. This model used the "spiral bevel", 4 stud axle like the BN1.
Even with the 3.6 in a BN1, "bottom" gear is still way too low to be any use on the road. I know, I have tried it.
