Hi Guest!
What about spray carpet cleaner? The kind that foams up then when dry you brush it off.
I'm thinking that wiping alcohol on/off would have the same issue. Also, alcohol might affect the colored thread. I would probably try Windex or something where wiping isn't required to soak it and let dry.I'd be leery of anything that leaves a residue you have to brush off as I'd be worried the residue would get caught in the weaving and be impossible to get out. I haven't done it so you'd have to test it first, but maybe wiping with alcohol would work?
To be clear, the harness is out of the car. And, the cloth fibers are in very good condition. Based upon what Ray just said, I think I should be able to put the entire harness into a bathtub with a mild detergent and gently agitate to get it clean? I was originally concerned that there might some kind of plastic wrapping under the cloth that could trap water and not completely dry out.
